How can Autodesk help me? FIX my problem, why display save?
Alfred.NESWADBA
welcome @Anonymous!
Best start would be if you describe your problem
From your screenshot you might search for FILEDIA ... set it to 1 so you get a dialog instead of needing to type a filename
If you search for anything else then please let us know what you are searching for!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
TheCADnoob
Judging from your screen shot i agree with @Alfred.NESWADBA. If thats not the issue perhaps you are talking about the dynamic input. you can change that with DYNMODE and this will have you using only the command line.
CADnoob
