create points & export
Message 1 of 8
how do you create a point with description and export points to asci file using auto cad 2016LT
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Create a block with an attribute, then use command _INSERT to position that block and fill the attribute with the description.
I guess AutoCAD LT 2016 has the command _DATAEXTRACTION, if that does not work then please look to command _ATTEXT.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
john.vellek
Hi @Anonymous,
I made a short video for you to see the process. I have also included a sample drawing with my block, a template file, and a sample output file.
Please let me know if this helps.
John Vellek
Message 4 of 8
what if i create a point, will i not get the same results.  How did enhanced attributes.JPGyou create
Message 5 of 8
john.vellek
Hi @Anonymous,
I created my point with true geometry rather than using a node. This is a personal preference.
The attributes might make a difference in the extraction.  Why don't you attach your point block and let me take a look for you.
John Vellek
Message 6 of 8
all i did is create a point.  I switched companies and there running older version of auto cad 2016lt instead of usual civil 3d
Message 7 of 8
john.vellek
Hi @Anonymous,
I added your point to a block with some attributes.  I modified the extraction template slightly and it is successful in capturing the point information.  I hope this is doing what you are asking.
John Vellek
Message 8 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
