Does anyone have any clue what this error is?
it is constantly causing one of our user terminal errors.
thanks!
Solved by john.vellek. Go to Solution.
Solved by Edwin.Saez. Go to Solution.
YOU MUST HAVE INSTALLED ANY APPLICATION, AND THAT APPLICATION IS ERROR SOME, THEN YOU MUST BE COMING FROM FATAL ERROR. UNINSTALL APPLICATION.
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
Hi @Anonymous,
This error message is an indication of a corrupt drawing. Has this user tried to run AUDIT or RECOVER on the file? Which version of AutoCAD is in use and on which Operating System?
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
