Datalinking and Alternatives
- Mute
- Permalink
- Report
Background:
I work with large project groups in my office. For various reasons, everyone has different versions of Autocad (LT vs Full, 2015 vs 2016 vs 2019, etc) and things like our local share drive is mapped by user preference. Everyone's skill level with autocad is also very different, ranging from no skill to "average" usage.
Problem:
Due to everyone's lack of autocad skills, many people prefer to make tables in excel. The file is then datalinked and the table is created in autocad and the sheet is made. I often run into the following issues:
- datalink will sometimes insists on a FULL PATH instead of a RELATIVE PATH, which often breaks because due to how people map to sharedrive
- tables refuse to update despite telling it to update
- big projects will easily have 50+ tables so constantly trying to fix the broken links or manually updating the tables is not ideal.
Questions
1) Is there a better alternative than datalinking? Or is datalinking the only way to get excel files into autocad that can be updated later down the road?
2) Why does datalinking insist on full path sometimes? How can I fix this?
3) Why does it fail to update sometimes? Is relinking the only way to fix this?
There are a lot of moving parts to this so I understand if there isn't a one solution all to this. Datalinking is constantly failing for us and I can't isolate if it's just because too many people are going in and out the files or due to different versions of autocad or sometimes just the simple issue of people taking work home and then changing the path. There's simply too many people and not enough time and money to bring them all up to the same skill level/computer set up/same versions.
I've had one project where someone handed me 20 tables to update, I tried to update the datalinks and it failed so I spent the rest of the day fixing the links only for that same person to come back 2 days later with another 15 tables and it was a toss up which tables would update and which ones didn't.
In a nutshell, is there a better method than datalinking? If not, what can I do to minimize the issues I keep running into? Do I have to insist that only one person can touch the files with datalinks in them?
