DATAEXTRACTION coordinates sequence question
Message 1 of 24
Dear all:
I used spline to plot a path, after this I changed this path to pline and divided with 0.1 meter interval. Then I use DATAEXTRACTION to export the coordinates of every point on the pline to Excel file, and I try to plot the path in MATLAB. However, I found that the sequence of the (X, Y) coordinates is not from the beginning of the path to the end of the path, but in a kind of order that I don't want.
Could you give me some guidance on how to make the exported coordinates of the path from the start point to the end point?
Thank you very much.
Replies (23)
Message 21 of 24
arshadmirza786
Message 22 of 24
ВeekeeCZ
Hi @arshadmirza786
You're wrong. There are so many people willing to help, I can see that every day.
I can't help you because I simply don't understand you. Not to text, neither to drawings. My English isn't perfect so I'm having so hard time of trying to understand your text where is every second word misspelled. There are so many tools on internet that you can use to correct your text for free!
Take the time, fix the grammar, illustrate the issue on drawing with short and clear comments, show what's wrong about the current tool and how should the correct result look like...
Message 23 of 24
arshadmirza786
Sorry for disturbimg with my english spellings and grammer
No comments for help on lisp forum
my promlem is
the attached dwg file show a pline breaked on 76.2 + some end points of curves & the given distance to pldiv+2file is also 76.2
when i count the segment of dwg with "nvert.lsp" it become =303
the "pldiv+2file.lsp" make a csv of 584 rows/ segments,
pls guide the "pldiv+2file to generate the 303 rows/ point data
Hopfully I have explained my problem
Message 24 of 24
ВeekeeCZ
My routine was not meant to work this way.
Not sure why you used some other routine to add vertices by 76.2 distances. Why did you do that?? My routine basically does the same (but just "virtually"), then you have each point twice.
Use my routine on the original alignment (line - arc - line) and you'll get the correct result - as I've tried to demonstrate you in attached file.
