DATAEXTRACTION coordinates sequence question
Message 1 of 24
Dear all:
I used spline to plot a path, after this I changed this path to pline and divided with 0.1 meter interval. Then I use DATAEXTRACTION to export the coordinates of every point on the pline to Excel file, and I try to plot the path in MATLAB. However, I found that the sequence of the (X, Y) coordinates is not from the beginning of the path to the end of the path, but in a kind of order that I don't want.
Could you give me some guidance on how to make the exported coordinates of the path from the start point to the end point?
Thank you very much.
Replies (23)
Message 2 of 24
ВeekeeCZ
You can't rely on it. Here is something you can rely on. Command name is bold.
Edit: You can select any geometrical object like polyline, spline, line, arc, circle. No points needed.
Spoiler
(defun c:pldiv2file ( / *error* file aa en int i mx file)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if file (close file))
    (princ))
  (princ "\nRequired single geometrical object, ")
  (while (not (setq ss (ssget "_+.:E:S" '((0 . "*POLYLINE,SPLINE,ARC,CIRCLE,LINE"))))))
  (initget 7)
  (setq int (getdist "\nSet interval: ")
	en (ssname ss 0)
	i 0.
	mx (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
  (if (setq file (open (strcat (getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) ".csv") "a"))
    (progn
      (while (< i mx)
	(if (setq pt (vlax-curve-getPointAtDist en i))
	  (write-line (strcat (rtos (car pt) 2) "," (rtos (cadr pt) 2) "," (rtos (last pt) 2)) file))
	(setq i (+ i int)))
      (if (setq pt (vlax-curve-getPointAtDist en mx))
	(write-line (strcat (rtos (car pt) 2) "," (rtos (cadr pt) 2) "," (rtos (last pt) 2)) file))))
  (*error* "end")
Save it as *.lsp, and see HERE how to run this. In case you do't now already.
Message 3 of 24
Dear Sir/Madam:
Thank you very much for the reply, I 've followed your instruction on that website and tried myself. However, after I typed pldiv2file into the command window, it asked me to select the object. I chose the path, but nothing happens, and the command window still requires me to select an object. I don't know whether I did something wrong. Could you give me some guidance? Thank you!
Message 4 of 24
ВeekeeCZ
Assuming you have your file saved.
Routine allows you single selection of one of these types of entity: "*POLYLINE,SPLINE,ARC,CIRCLE,LINE"
Then you specify an interval.
Then go to working folder of your current drawing and look for a file with the same name and *.csv
BTW. Points are always added at the end of the file. You can add one line to separate reports from same file.
Spoiler
    (princ))
  (initget 7)
	en (ssname ss 0)
	i 0.
    (progn
      (write-line (strcat "---- " (rtos (getvar "CDATE") 2 4)  " ---------------") file)
      (while (< i mx)
	(setq i (+ i int)))
  (*error* "end")
Message 5 of 24
Thank you! Now it works! Beautiful 🙂
Message 6 of 24
Hi, I tired to spline, but I stuck at the step to choose the object. However, if I convert the spline to pl, then I can use the code to select the object, define the interval, and output the csv file. Could you let me know where I did wrong for the spline? According to your last reply, it seems the code should also work directly on spline right?
Message 7 of 24
ВeekeeCZ
No special requirements for splines - it works for me. Make sure that you're using the latest version - post 4, posting again. My first version was limited for lwpolyline... but I edited the code couple minutes after first version was released (see edit note). If still this does not work for you, post the sample dwg were it's not.
Spoiler
(vl-load-com)
    (princ))
  (initget 7)
	en (ssname ss 0)
	i 0.
    (progn
      (while (< i mx)
	(setq i (+ i int)))
  (*error* "end")
Have fun with MatLab! I hated these couple seminars we had...
Message 8 of 24
arshadmirza786
Pls. add an "object snap" to end OR write in select object " select object from a end of line"
Message 9 of 24
arshadmirza786
Thank you to #BeekeeCZ for this "pldiv2file.lsp"
Should u pls. add some words for "END POINT OF A SEGMENT OF PLINE" in addition to the distance already specified
it is a geat help I hope you should improve it
Message 10 of 24
ВeekeeCZ
Hi @arshadmirza786, sorry I don't understand what you need.
Would give me some example of txt outcome? thx.
Message 11 of 24
arshadmirza786
I hope attached dwg file will explain what I says
Message 12 of 24
ВeekeeCZ
Still one question, meaning of your 1st point.
Does it mean that the calculation should start from the end which is closer to the point where the selection was made?
Message 13 of 24
arshadmirza786
sorry, START POINT (one side end/ start point of object) not from I click the object,
As per my observation it start from where I click the object
Message 14 of 24
ВeekeeCZ
Well, it's little complicated now... hope I understood you well.
I've added a default value for an interval, you can change it to by your preference, red.
(vl-load-com)
(defun c:pldiv+2file ( / *error* file ss en obj pt dst par file)
    (if obj (vla-delete obj))
    (princ))
  (if (and (setq ss (ssget "_+.:E:S" '((0 . "*POLYLINE,SPLINE,ARC,CIRCLE,LINE"))))
           (setq en (ssname ss 0))
           (setq pt (cadar (cdddar (ssnamex ss))))
           (setq pt (vlax-curve-getClosestPointTo en pt))
           (setq pt (progn
                      (if (> (vlax-curve-getDistAtParam en (vlax-curve-getParamAtPoint en pt))
                             (/ (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) 2))
                        (command "_.REVERSE" (setq en (vlax-vla-object->ename (setq obj (vla-copy (vlax-ename->vla-object en))))) ""))
                      (vlax-curve-getStartPoint en)))
           (or *pldiv2file-int*
               (setq *pldiv2file-int* 500))
           (not (initget 6))
           (setq *pldiv2file-int* (cond ((getdist pt (strcat "\nSet interval <" (rtos *pldiv2file-int*)">: ")))
                                        (*pldiv2file-int*)))
           (setq dst 0.
                 par 0)
    (while (<= par (vlax-curve-getEndParam en))
      (if (setq pt (vlax-curve-getPointAtDist en dst))
      (cond ((equal par (vlax-curve-getEndParam en))
             (setq par (1+ par)))
            ((or (> (vlax-curve-getParamAtDist en (+ dst *pldiv2file-int*)) (1+ par))
                 (not (vlax-curve-getParamAtDist en (+ dst *pldiv2file-int*))))
             (setq par (1+ par)
                   dst (vlax-curve-getDistAtParam en par)))
            (T
             (setq dst (+ dst *pldiv2file-int*))))))
  (*error* "end")
Message 15 of 24
arshadmirza786
Thank you for this great help
but it has born twin problem
1- The pline length is 7638 ft but in CSV file no body guss and add 250 ft againt each set of coordinate, so the length become 8500ft
Pls add a new column for distance and the specified intervel and end of segment be writen in CSV file
2-
Message 16 of 24
arshadmirza786
2- the end distance of segment be wrriten on dwg for appropriate distance, corelating with dwg location
Message 17 of 24
ВeekeeCZ
Not sure if I understood you right, so I hope that following code will cover your needs.
(vl-load-com)
(defun c:pldiv+2file ( / *error* file ss en obj pt dst par lst)
    (princ))
  (if (and (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE,SPLINE"))))
           (setq pt (progn
               (setq *pldiv2file-int* 100))
           (not (initget 6))
           (setq dst 0.
                 par 0
                 lst '(0.))
    (progn
      (while (<= (setq par (1+ par)) (vlax-curve-getEndParam en))
        (setq lst (cons (vlax-curve-getDistAtParam en par) lst)))
      (while (<= (setq dst (+ dst *pldiv2file-int*)) (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
        (setq lst (cons dst lst)))
      (setq lst (vl-sort lst '<))
      (foreach e lst
        (setq pt (vlax-curve-getPointAtDist en e))
        (write-line (strcat (rtos (car pt)) "," (rtos (cadr pt)) "," (rtos (last pt)) "," (rtos e)) file))))
  (*error* "end")
Message 18 of 24
arshadmirza786
thank you for spare your time for this huge lisp,  if u like pls add this second request too
thanks
Message 19 of 24
arshadmirza786
Sorry sir
the new twin are borns
1- the length of 3 lines are different due to inner curve and outer curves and widening of left & right lines in some places
2- The length of center line should be Governing length
According to both outer line lenght should be adjusted and the distance at widening remain same
I hope you will address these to points
Thank you
Message 20 of 24
ВeekeeCZ
Hi @arshadmirza786,
I did what I could do to help you with your issue, but I am unable to cover all your newly born ones.
If you feel that you still need some help, feel free to post your question HERE to customization forums, where are more folks able to help with these kind of issues. Good luck!!
