I'm trying to print a sheet to a PDF format and the sheet has a Data linked table on it. Unfortunately the table will not show up when printing to PDF.
*AutoCAD 2022
Solved by imadHabash. Go to Solution.
Would you please check your layers status in plot tab from LAYER command ? i see also that your viewport limit ( green border ) did not print also .. check that layer .
Imad Habash
