I am using AutoCAD 2020 and want to achieve the following. (See attached drawing). The drawing shows all components in place on the left and the various components split up for clarity on the right.
I want to create a bill of quantities from a 3D drawing of a concrete pit. The components/process for creating the pit is as follows:
- Excavate hole. (Colour=Brown on the drawing).
- Backfill and compact 150mm layer on the pit floor. Colour=Cyan on the drawing).
- Cast concrete floor. (Colour=Grey on the drawing).
- After installing shutters, cast concrete walls. (Colour=Magenta on the drawing).
The data required is as follows:
- Pit Identification
- Component identification.
- The volume of the component.
Each component will be drawn on the layer unique to that component. Bear in mind that I've only drawn one pit, in reality, there are approximately fifty pits on this project. For example, there will be fifty soil excavations on the drawing all drawn on the soil excavations layer.
My idea is to select all the components for all fifty pits and extract the abovementioned data to a spreadsheet. after all the data is extracted, I'll have a spreadsheet that identifies each component for each pit and contains the volume for each component of each pit.
Thanks in advance,
Dave
