Extend command only works when typed
I've recently gone through and added some keyboard shortcuts to make my CAD work a little bit more efficient. Ever since I've done this, the Extend command has had a problem.
Originally, I had mapped the Extend command to CTRL+T, overwriting the tablet command. However, I quickly realized that executing the command now did absolutely nothing. I remapped it to CTRL+E, and it didn't work either. It didn't try executing anything else, it just did nothing. I tried clicking into the command, and that doesn't work anymore either. The only way I can execute the extend command now is by typing it into the command bar. Has anyone encountered this problem before, or have any suggestions on fixing it?
pendean
Community Legend
Community Legend
X is the abbreviation I use for Extend: X then spacebar (which acts as <enter>) works all the time.
T for TRIM also.
And if you are in either command and hold the shift key down you get the other command.
Use the spacebar as <enter> is my advice.
GrantsPirate
Did you set the CTRL+T by typing each letter?  Or did you pick the little ellipsis button on the far right and hold down CTRL button and then hit the T button?  What does your macro say?
See attached for an example.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
