cut and paste also block insert not working
I am not able to cut/ paste some details from one drawing into another or insert the details as a block. I need this done ASAP. Please HELP!!
pendean
Community Legend
Community Legend
"some details" may be the key here: what are these? What error message is listed in the commandline (press CTRL+F2 to expand it)?
I bet you cannot WBLOCK these "some details" too, correct?
rkmcswain
Why not? What is stopping you? Error messages? Error dialogs? Post them here.
R.K. McSwain     | CADpanacea | on twitter
S.Faris
Are they Blocks or does the detail contain blocks?
In that case there might be a block name conflict,and you might have to rename the blocks in either one of the files before copy pasting or inserting. Refer to this : How to rename named objects in AutoCAD
SALMANUL FARIS
s.borello
We really need more info to try and come up with a resolution... If all else fails and you can't get copy/paste to work, you can always xref them in.
murray-clack
It MAY be that you have AEC objects in your selection set that you are copying to the clipboard.
However... Here is a trick that works for me:  Before you "Paste", simply click on ANY object in your current drawing (i.e. click on a line or a circle, etc) and then try to paste
