Custom Viewport Scale in AutoCAD
Message 1 of 10
Hi
If I have the map on scale 1;1.700.000 where I go on viewports  which is the value on cutom scales for this scale  and  how can I found the real value that  I can put here for this map
@Anonymous, john.vellek has edited your subject line for clarity:CUSTOM QUESTOM
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Viewport scaling is done here
Message 3 of 10
Hi
Again for my scale which the value custom scale
Message 4 of 10
john.vellek
Hi @Anonymous,
Go to the scale list as indicated by Dean and then select custom. You will then see the Edit Drawing Scales window. Select an existing scale or create a new one and then use the Edit button to set the ratio.
John Vellek
Message 5 of 10
ВeekeeCZ
Select your Viewport, run PROPERTIES palette, there is Custom Scale item. Here you can set any scale you want.
Message 6 of 10
pendean
Community Legend
Community Legend
>>>...Again for my scale which the value custom scale...<<<
See the work CUSTOM on that tall list, towards the bottom?
Your welcome 🙂
Message 7 of 10
Sorry again Dean i want the scale 1:1.700.000. What can I do, on custom scale for make this value can you help you
Message 8 of 10
john.vellek
Hi @Anonymous,
Here is a video showing how to add the scale to your scale list.
John Vellek
Message 9 of 10
ah, young people used to big button layout....
there is a toolbar palette called "Viewports" which allow to set a custom scale by typing the exact scale you want, without the need to edit the "drawing scale" lists (you might want to do this for various reason, such as "list already messed up by redundant scale found in xref").
To access this toolbar, you can either right click on any other toolbar and select from the list the one called "Viewports".
otherwise, you can type "-toolbar", then "viewports" and then "show".
Once the toolbar is in place you can type any number in there, and you'll have custom scale.
Message 10 of 10
RobDraw
What's a toolbar?
Rob
