How to DELETE constraint
BIM_Dreamer
BIM_Dreamer
hello expert, I tried in the command DELCONSTRAINT and even go to parametric and used delete constraints but still i cannot delete the dimensions contraint . what shall i do. need your help. thanks
Alfred.NESWADBA
the screenshot does not show constraints, it shows warning symbols for dimensions not beeing assigned correctly to an object's point/vertex.
You can reassociate the dimension(s) (>>>details<<<) or turn off ANNOMONITOR (>>>details<<<).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
BIM_Dreamer
@Alfred.NESWADBA thank you for your reply, those icon can be deleted. just one more question Project units in autocad is the same as ddunits set-up? thanks
Alfred.NESWADBA
Maybe I misunderstand something? You can't select the icon and you can't delete them. It's not a constraint showing up in your screenshot (or I don't see what you mean, I see a lot of yellow question marks).
ANNOMONITOR is just a variable to show or to not show the warnings, they are not deleted or the issue is not repaired by just turning them off.
That's what I mean:
"Project" is a word that has to used carefully for AutoCAD, AutoCAD itself does not know a project like AutoCAD Architecture or other verticals.
Within the drawing I suggest to use command -DWGUNITS and set it to the unit type you are drawing your parts.
- alfred -
Alfred NESWADBA
BIM_Dreamer
@Alfred.NESWADBA thank you, learned something new.
DELCONSTRAINT is a beautiful command. Thanks
