Hello, I'm trying to create a util linestyle and get the above error message.
I want it to look like: G - - - (D) - - - G --- (D) --- G
that is how I started it. Text, 3 lines, Text, 3 lines.
Any help is appreciated.
Solved by chriscowgill7373. Go to Solution.
Can you provide you current code for your line? I would say based on the error, you are trying to code too much
You can only have between 2 and 12 dash/dot specifications. Text, 3 lines, text 3 lines, would be too many (each gap counts as well)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
I can't post it because it won't create it. I believe your correct tho and wanted to confirm I can't.
Presenting it as: --- G(D) ---, seems to work.
I wanted the G and (D) to be separate, but that seems to be too much.
Thank you for your reply!
Were you coding it or trying to create it from a drawing? I went straight to coding it, which is what told me about the 2/12 requirement. What about separating them by 1 dash so you would have dash g dash d dash dash as your definition. The dash and g would not be able to be gapped that would cause the 12 count to be exceeded
I was using lines and txt in a file with the express tool MKLTYPE.
Yeah, I will play with it more and see what will work best.
--- G(D)--- seemed to work.
I'll try your suggestion too.
Thanks for your reply!
no problem
as a note, --- g (d) --- as you have it written would have 6 dashes when drawn as the pattern repeats
--- g (d) --- --- g (d) --- --- g (d) --- --- g (d) --- --- g (d) --- --- g (d) --- --- g (d) --- --- g (d) --- --- g (d) ---
is what you will see
as opposed to
- g (d) -- - g (d) -- - g (d) -- - g (d) -- - g (d) -- - g (d) -- - g (d) -- - g (d) -- - g (d) --
To add to the information provided by @chriscowgill7373, the following Autodesk Knowledge Network (AKN) articles cover linetypes as well as the limitations in a linetype definition.
All the best,
