Good Afternoon,
I've recently installed AutoCAD 2018 on a machine using a 3840x2160(4K) main monitor, and a 1920x1080(1080p) secondary monitor that previously used AutoCAD 2017. I'm aware that 2017 did not officially support 4K and some elements(layer/properties/xref windows) did not scale correctly due to DPI scaling within windows 10(64 bit), but the majority of it worked just fine. Custom Icons automatically loaded the 32x32 editions(where available), and appeared clearly.
I've installed 2018, and when opening it, all of the toolbars are scaled in an odd format to cause them to become blurry, and not fill the toolbar frames properly. If i toggle the "use large buttons for toolbars" option under display, on and off, it causes the toolbar frames to become the correct size, but the icons are still small and blurry. Other elements seem to have scaling issues as well.
I've tried changing the compatibility settings to ignore dpi scaling, disconnected the secondary monitor and tried using the 1080p monitor as my main desktop, to no avail. AutoCAD 2017 continues to work *almost* properly.
Has anyone seen any behavior similar to this before? Could it have something to do with migrating profiles from 2017 to 2018?
I've included some photos for comparison. It appears the toolbar frames try to be the right size in 2018 after the size option is toggled, but icons are still small and scaled to something that isn't 16x16 or 32x32...
Toolbar setup for AutoCAD 2017 (large buttons turned on)
Blurry AutoCAD 2018 before setting change
Blurry AutoCAD 2018 with Large Buttons turned off
Blurry AutoCAD 2018 with large buttons turned on
