Custom Brick Hatch Pattern
Message 1 of 10
Hello everyone,
I need help with creating a hatch pattern for brick.
Brick dimension is 2.5x8.75" with 0.25" mortar joint.
I have created the pattern, but it is giving me an error saying  "missing parameter on line 7"
Could anyone give me an advice on how to fixing this?
*8in Ontario Size Brick, 3 COURSES TO 8.25 inch
0, 0,0.25, 4.5,3, 8.75,-0.25
90, 8.75,0.25, 6,9, 2.5,-3.5
0, 0,3, 4.5,3, 8.75,-0.25
90, 0,0.25, 6,9, 2.5,-3.5
90, 4,3.5, 6,9, 2.5,-3.5
90, 4.5,3.5, 6,9, 2.5,-3.5
This is what I have done for the PAT file.
Let me know.
Replies (9)
Message 2 of 10
hugha
Try this:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2020 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2020-11-21
;-Time : 12:26:52
;-HatchKit 4 Version : 4.0.9.2894
*8inOntarioSizeBrick,3 COURSES TO 8.25 inch
0,0,.25,-4.5,3,8.75,-.25
0,0,3,-4.5,3,8.75,-.25
90,8.75,.25,-3,4.5,2.75,-3.25
90,0,.25,-3,4.5,2.75,-3.25
save the above with a blank line at the end to file 8inOntarioSizeBrick.PAT on your source file path.
Note:
1. a blank line is required as the last line within the .PAT file
2. pattern and filename can only contain  characters A-Z, a-z, 0-9, $, _ (underscore) or -(hyphen).
hth,
Hugh Adamson
www.hatchkit.com.au
Message 3 of 10
Thank you for the reply Hugha,
I have tried it, but it gives me an AutoCAD error for some reason.
does it work on your end?
could you email me your PAT file?; lee.seungyoon.architect@gmail.com
I overwritten on my mine with blank line added, but still not working.
Let me know.
Thank you.
Message 4 of 10
Patchy
This is what he gave you.
(You should delete your email address or hackers will spam you)
Message 5 of 10
Thank you.
I fixed the issue and it is working now.
I modified little since the birck was 2.5x8.75.
Just for my better understanding.
in the mid portion, -4.5,2.75,  why is it negative 4.5 instead of positive?
Could you explain to me? I am getting confused with it.
Thank you so much.
Message 6 of 10
Patchy
Message 7 of 10
ELAZATIN
anyone have a hatch for size of bricks 230mm x 70mm and 10mm GAP?
Message 8 of 10
hugha
Try
; Written by HatchKit 4 Team Edition
; HatchKit 4 Team Edition (c)1990-2022 Cadro Pty Ltd
;-Date : 2022-08-04
;-Time : 16:12:42
;-HatchKit 4 Version : 4.2.3.3303
;-HatchKit 4 Output Filetype : AutoCAD®
*Brick230x70,QuickFill: Stretcher bond
0,0,70,120,80,230,-10
0,0,0,120,80,230,-10
90,230,0,80,120,70,-90
90,0,0,80,120,70,-90
hth,
Hugh Adamson
hatchKit.com.au
Message 9 of 10
abeltran4UPT9
Community Visitor
Community Visitor
Hi all,
Anyone has the custom brick code pattern for the 230 X 76 (110 DEEP) with the 10mm mortar joints? This is the standard Australian brick size. Thanks for any help.
Ariel B
Message 10 of 10
hugha
Try:
;-Date : 2022-08-10
;-Time : 00:32:12
*B230x76x10,QuickFill: Stretcher bond
0,0,76,120,86,230,-10
0,0,0,120,86,230,-10
90,230,0,86,120,76,-96
90,0,0,86,120,76,-96
hth,
Hugh Adamson
www.hatchkit.com.au
