Hi -
Here's my problem.
I have a wall curved around an elliptical arc.
The wall is currently 48" all the way around.
What I'd like to have happen is wall change height from 48" to 36" as it curves around the wall.
How do I go about doing this?
-Michael
Solved by GrantsPirate. Go to Solution.
brick wall, adobe, interior, ?
In plan view, label it. in elevation, draw it
if you want something else, you're going to have to explain more
You can get there easy enough with Loft. Draw the two cross sections at the end points of the ellipse, use loft and use Guides and pick the elliptical arc. I just tried it and it works like a charm.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I got it to work with using PATH, not guide for some reason.
Thanks!
I always forget about LOFT
