AutoCAD Forum
Curved Wall with a slight grade - Elliptical
4 REPLIES 4
822 Views, 4 Replies
Hi -
Here's my problem.
I have a wall curved around an elliptical arc.
The wall is currently 48" all the way around.
What I'd like to have happen is wall change height from 48" to 36" as it curves around the wall.
How do I go about doing this?
-Michael
4 REPLIES 4
jggerth
brick wall, adobe, interior, ?
In plan view, label  it.  in elevation, draw it
if you want something else, you're going to have to explain more
in reply to: jggerth
I am trying to make a 3D model in CAD.
Shouldn't matter what the material is.
Thank!
/mg
michael goldsheft : poisson rouge
13-15 W. 28th st : Suite 10A : NY 10001
[o] 1.212.473.9704 x103 [o] 1.323.952.5900
[c] 1.714.655.1945 www.513e12.com
GrantsPirate
You can get there easy enough with Loft.  Draw the two cross sections at the end points of the ellipse, use loft and use Guides and pick the elliptical arc.  I just tried it and it works like a charm.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
in reply to: GrantsPirate
I got it to work with  using PATH, not guide for some reason.
Thanks!
I always forget about LOFT
Forma Design Contest
