Curser turns into a No Entry Symbol - Problem solved Filedia
Message 1 of 12
Whilst trying to open up AutoCAD files using the Open function through the AutoCAD interface the usual open dialogue box does not appear and when I try and select something else the mouse curser turns into a No Entry symbol (red circle with diagonal red line through it) even pressing Esc does nothing and I am unable to close the program without ending the task in task manager. I have restarted my PC and tried again and it is still the same.
Replies (11)
Message 2 of 12
billfridley4799
Observer
Observer
im having the same problem, whenever i place the pointer over a drawing tab or the cmd line i get the  "ghostbusters sign" or nay symbol
Message 3 of 12
any fix for this?
Message 4 of 12
Ed__Jobe
Do you have FILEDIA set to 1?
Ed
How to post your code.
Message 5 of 12
yes
Message 6 of 12
Ed__Jobe
What are the steps to reproduce this? Does it do it all the time?
Ed
Message 7 of 12
Any chance there is a solution to this?  I tried changing the setting but still persists.
Message 8 of 12
Toon.Broothaerts
I also have a user reporting this. Anyone got an update for this?
Toon Broothaerts
If my answer solved your question, please mark it as 'solution'. Else, feel free to contact me!
Message 9 of 12
I have the problem when I started from a drawing done by someone else. Doesn't seem to effect anything - just annoying. Selected all and copied into a new drawing and the problem followed!
Message 10 of 12
Restarted AutoCAD and back to an arrow cursor 🙂
Message 11 of 12
pendean
Community Legend
Community Legend
@Anonymous Can you post a screenshot of both your ABOUT and GRAPHICSCONFIG command pop-ups please.
Message 12 of 12
bwilliams
Observer
Observer
Same problem just occurred  DOE sign curser when on command line and command ribbons.
Started when I opened a file for a consultant.  Went away after closed program and restarted.
