CUIEXPORT & CUIIMPORT is this what I must do?
dbirdAQVYP
Observer Observer
dbirdAQVYP
Observer
Observer
Trying to get a few custom commands from old system/version (2021) to new system and version 2026. I attempted to backup all settings using the AutoCAD app but it created a corrupt zip file (more than once). Can I use the CUIEXPORT and CUIIMPORT procedures to get these commands copied over?
pendean
Community Legend
Community Legend
@dbirdAQVYP wrote:
... Can I use the CUIEXPORT and CUIIMPORT procedures to get these commands copied over?
Can you use, while in an AutoCAD 2026 session, CUI command's Transfer tab to move content from your 2021's CUIx file to your 2026's CUIx file? Assuming both CUIx files (not programs) reside on the same PC of course.
imadHabash
Yes, you can absolutely use CUIEXPORT and CUIIMPORT to move your custom commands from AutoCAD 2021 into 2026.>>Click<<
In this >> LINK  << also you will find a table lists the custom settings and files that are migrated or transferred each time you use Export/Import Settings or Migrate Custom Settings utility.
Imad Habash
