Help me with the drawing - AutoCAD 2022
gukuvegetasherif23
Message 1 of 15
gukuvegetasherif23
Can anyone tell how can i drew that i know i must use polygon but didn't know what to do after
@gukuvegetasherif23 Your post title was modified to add the product name and version and to increase findability - CGBenner
Replies (14)
Message 2 of 15
leeminardi
Post an AutoCAD file of what you are able to do for both constructions.
lee.minardi
Message 3 of 15
imadHabash
For the left image ...
You can draw it by POLYGON command ... all what you have to do is to change the number of side for every polygon shape starting from 3 till 10 then enter E for Edge option and pick two corners at 10.00.
Command: POLYGON
Enter number of sides <>: 3
Specify center of polygon or [Edge]: E
Specify first endpoint of edge: Specify second endpoint of edge:
For the Right image ...
I'll give you a hint .. you have 6 arrayed objects. Just draw one of the six then use array command ... Let us see your attempts and through them we can help you more.
Imad Habash
Message 4 of 15
gukuvegetasherif23
I used offest  2 between each so i can make same shape but iam kinda lost and how i cam incorporate array to this
Message 5 of 15
imadHabash
Good start ...
The center of circle in my massage #3 is the center of Array(Polar) procedure. You have to trim the object first then use array command from the point that i describe it for you. Keep going your try and get back for any question. >> Click <<
Imad Habash
Message 6 of 15
gukuvegetasherif23
How can i use the rows and columns so i can replacte the shape and where fo i trim
Iam not that experienced in array srry
Message 7 of 15
imadHabash
You have to use Array command with Polar option.. Click on below image
Imad Habash
Message 8 of 15
imadHabash
I have attached an illustration image in my previous massage #7 for you.
Imad Habash
Message 9 of 15
gukuvegetasherif23
what about this i did the circle and as u toldi did the polar array with fillit on the circle but i cant seem to know what do in the middle shape and what does angle 45 mean
Message 10 of 15
imadHabash
Good start ...
Just draw the first vertical line ... then fillet it with the circle (0.40) then array it (Num=8) then Mirror all the 8 to get the final needed result.
Imad Habash
Message 11 of 15
gukuvegetasherif23
I did like in the vid and it showed up like this
Message 12 of 15
imadHabash
Make sure that distance=0.60 from the vertical axis is achieved.
Imad Habash
Message 13 of 15
gukuvegetasherif23
My bad i writed the distance wrong
Message 14 of 15
gukuvegetasherif23
With this i tried everything i tried going from quadrant 2.5 left and line up and fillet didnt work
Message 15 of 15
shift_enter_inc
Observer
Observer
Hi! If you want to draw that shape using a polygon, here’s a simple way to start:
  1. Select the polygon tool in your software.
  2. Click to place each vertex of the shape, connecting them in order.
  3. Close the polygon by connecting the last point to the first.
  4. You can then adjust the edges or vertices if needed, depending on your software.
If you tell me which program you’re using, I can give step-by-step instructions for that specific tool.
