CUI editor not working
Working in AutoCAD 2017, I would like to change a few of my keyboard shortcuts. I did the following:
Display the Customize User Interface (CUI) Editor
  • Click Manage tab  Customization panel  User Interface.
And I got the following message in my command strip:
Command: _cui Unknown command "CUI".  Press F1 for help.
Not sure why, when I click on the CUI button autocad says it's an unknown command???  Can anyone help with this? Also, could there be another way to change/create a keyboard shortcut?
cadffm
Is there a cad-manager/cad-administrator in your company?
Try command _.CUI
Sebastian
user181
You can also use  _ALIASEDIT  to edit keyboard shortcuts
Alfred.NESWADBA
try to enter the command in that way:
_.CUI
(including underline and point)
If you get the same message again you might need to reset the AutoCAD profile as described >>>here<<<.
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
