We've installed, and I rebooted, but I'm still not seeing any difference.
Allow me to explain. The tag that is attached to the cursor, says typical things like... When I press "E" for erase, the tag says "Select objects:" But it stays, causing a barrier so I can't see what's behind the phrase to select. This may or may not be the cursor badge.
If this IS the cursor badge, then whether I select 1 or 2, there appears to be no difference for me.
The annoying part of this feature is that when I type in my commands, the command appears in the command window (command box), but sub commands appear next to the cursor, not in the command window, so part of the time I'm confused about where I'm at in the command, and end up having to do the command over.
What I want, is to remove this dialogue box from the cursor altogether, so the cursor is just a cursor, no tags, no dialogue box, just the crosshairs and pick box, and that's all.
Does this clarify anything?
Again, my thanks and apologies to you good folk
Mark
