Can anyone help me out with this problem? I click the mouse to use the pan but it seems it change to the setting...I tried to reset the setting to default but it could not work as well.
And everytime I click to select the drawing or lines it turns up like a dot tat the crosshair.
Cheers,
Hilmi
Solved by skintsubby. Go to Solution.
Hi Hilmi
Welcome to the forums.
Type the following into the command line and hit enter.
(setvar "BLIPMODE" 0)
Regarding small dots you can get rid of thim by blipmode variable sitting.
Good Luck..
Imad Habash
Let's see the drawing, I know the virus called Cambodia that do that and in YOUTUBE.COM there is a fix for it.
Is the problem in one file? show us your DWG file with the problem.
Is the problem in every DWG file, even if you start a new one? You've got bigger problems that just a cursor setting I suspect.
After looking at all snap shots I don't think open this drawing when it's attached here is a good idea. It 's known to have acad.fas attached to it.
Newer versions have setting of disabling it but anyone uses the older versions better be aware of the Cambodia virus.
