Crosshair problem
Crosshair problem
Can anyone help me out with this problem? I click the mouse to use the pan but it seems it change to the setting...I tried to reset the setting to default but it could not work as well.
And everytime I click to select the drawing or lines it turns up like a dot tat the crosshair.
Cheers,
Hilmi
Replies (14)
skintsubby
Hi Hilmi
Welcome to the forums.
Type the following into the command line and hit enter.
(setvar "BLIPMODE" 0)
imadHabash
Regarding small dots you can get rid of thim by blipmode variable sitting.
Good Luck..
Imad Habash
Hi,I can't set my crosshair back to normal. Can you identify this please?
regards,hilmi
pendean
Community Legend
Community Legend
What is your UCS and PLAN variables set to in that file?
Hi there,
UCS and Plan are normal and I didn't change it. Any clue or tips on UCS part? I've forgotten how to change the UCS and Plan setting.
cheers,Hilmi
Patchy
UCS use W
PLAN use C
Same problem and my crosshair didn't back to normal...I've installed and uninstalled my autocad 2013 but the problems is still there..
Sent from my iPhone
Patchy
DSETTINGS, Snap Grid, don't use Isometric then SNAPANG  use zero.
nope, can't do with it at all. this looks like a virus or cookies or something. it's unchangeable 😞
Patchy
Let's see the drawing, I know the virus called Cambodia that do that and in YOUTUBE.COM there is a fix for it.
I've no idea what kinda problem is this dude
pendean
Community Legend
Community Legend
Is the problem in one file? show us your DWG file with the problem.
Is the problem in every DWG file, even if you start a new one? You've got bigger problems that just a cursor setting I suspect.
Patchy
After looking at all snap shots I don't think open this drawing when it's attached here is a good idea. It 's known to have acad.fas attached to it.
Newer versions have setting of disabling it but anyone uses the older versions better be aware of the Cambodia virus.
pendean
Community Legend
Community Legend
