Crosshair during active command
DaveFuller
Message 1 of 10
DaveFuller
AutoCAD 2021. This is as simple as they come, I'm sure. I have crosshairs displaying when a command is active. How the heck do I turn that off?
Thanx in advance.
Replies (9)
Message 2 of 10
cheryl.buck
Autodesk Support
Autodesk Support
Hi @DaveFuller,
Can you clarify or provide a screen shot showing what you would like to turn off?
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 10
DaveFuller
Issuing LINE Command. Middle button for osnap menu, "e" for endpoint. the pickbox appears and the crosshairs should disappear until I select the endpoint.
Sheesh, I couldn't have been more vague before...
Down in the lower right
Message 4 of 10
cheryl.buck
Autodesk Support
Autodesk Support
Hi @DaveFuller,
That's interesting, I don't think I am not familiar with this feature. I tested through all the Options and the Osnap settings, but did not find any that did this. I can see how it would help with the selection process, though.
It sounds like the a white pick box (without crosshairs) shows when in a command until it encounters a snap point, and then the pick box turns to green, is this correct?
Which version were you able to do this in previously?
All the best,
Cheryl Buck
Message 5 of 10
DaveFuller
Thanx, Cheryl.
No, not quite.
This is after the osnap was selected, but nothing selected yet. I would expect a pickbox sans crosshairs. Is that a little clearer? It's driving me nuts, I keep thinking I not in a command.
Message 6 of 10
Kent1Cooper
@DaveFuller wrote:
This is after the osnap was selected, but nothing selected yet. I would expect a pickbox sans crosshairs. ....
You get the pickbox without crosshairs in object selection for editing commands, but not in drawing commands.  I don't recall it ever working as you describe in that situation.
Kent Cooper, AIA
Message 7 of 10
rkmcswain
Message 8 of 10
DaveFuller
Thank you for the response. This is not what I'm experiencing... this time. Yup, my cursor and crosshairs disappear completely from time to time. I'm talking about the crosshairs remaining when a command is active and an osnap has been selected. The crosshairs should disappear at that time, leaving only the pickbox.
Message 9 of 10
rkmcswain
To clarify. No running osnaps active (OSMODE=0).
Run the LINE command, initiate the 'ENDP object snap, then you expect the cursor lines to vanish, leaving only the pickbox?
Here is 2014, cursor still there.
Here is 2016, cursor still there.
Here is 2017, cursor still there.
Here is 2018, cursor still active.
Here is 2019, cursor still active.
and so on, and so on.
The cursor never disappears, in this scenario, in any version I can test.
Message 10 of 10
DaveFuller
Crosshairs, not cursor. In your configuration it may be so. I did not make this up. I am accustomed to the crosshairs disappearing for a command osnap.
