CROSS REFERENCE TABLE
I'm trying to add a Graphic Font Format table to a drawing. I've done the setup to get the image on the right, but the version on the left is what I end up with. Anyone know why?
john.vellek
Hi mark.grigas,
The two tables certainly don't look the same.  Can you attach both files so that I can better understand what you are trying to accomplish?
John Vellek
john.vellek
Hi @Anonymous,
It's been a couple days since your first post but I haven't seen an update. Did you resolve your problem with the tables or do you still need assistance?
John Vellek
1.jpgI want the one on the top, I keep getting the table on the bottom. the setup dialog doesn't work. I've done all the setups. they don't work. Solution?
Patchy
I think you should ask this group:
http://forums.autodesk.com/t5/autocad-electrical/ct-p/2035
