Cross polygon selection instead of lasso selection?
Message 1 of 9
Hey!
Is there any way to customize the lasso selection with mouse and replace it with the cross polygon command?
As I use CPolygon much more...
If not, an alternative solution would be editing in-line command letters (pressing CP when using the SELECT command) with closer keystrokes.
Cheers!
Replies (8)
Message 2 of 9
Alfred.NESWADBA
when lasso selection is started just press <SPACE> as often as needed to change the mode of lasso ==> crossing/window/fence ... does that help?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
gotphish001
Space doesn't toggle to the option of polygon though. I think that what OP is looking for.
Nick DiPietro
Cad Manager/Monkey
Message 4 of 9
Exactly, Cross Polygon fits best my needs.
Message 5 of 9
sthompson1021
Not sure of a way to to edit the inline CP, but it's easy to assign a shortcut key to the select-cp command in the cui.
Message 6 of 9
So,  I solved it by creating a custom lisp, my first one 🙂
(defun C:CS ()
(command "select" "cp")
(defun C:CSS ()
(command "select" "wp")
Thanks anyways for your replies!
Message 7 of 9
Hi! I would also like the polygon back instead of the lasso, but I'm not advanced enough to understand how to employ that lisp? any recommendations?
Message 8 of 9
neaton
If you want lasso sometimes remember a lasso selection is click and drag, whereas polygon window is click, click.
If you want to turn off the lasso option all together in Options, Selection, deselect Lasso check box.
Nancy
Message 9 of 9
Same as PICKAUTO 1
