Anuncios
Cross polygon selection instead of lasso selection?
No aplicable
Hey!
Is there any way to customize the lasso selection with mouse and replace it with the cross polygon command?
As I use CPolygon much more...
If not, an alternative solution would be editing in-line command letters (pressing CP when using the SELECT command) with closer keystrokes.
Cheers!
0 Me gusta
Responder
Soluciones aceptadas (1)
2.704 Vistas
8 Respuestas
Respuestas (8)
Alfred.NESWADBA
when lasso selection is started just press <SPACE> as often as needed to change the mode of lasso ==> crossing/window/fence ... does that help?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
gotphish001
Space doesn't toggle to the option of polygon though. I think that what OP is looking for.
Nick DiPietro
Cad Manager/Monkey
No aplicable
Exactly, Cross Polygon fits best my needs.
0 Me gusta
sthompson1021
Not sure of a way to to edit the inline CP, but it's easy to assign a shortcut key to the select-cp command in the cui.
0 Me gusta
No aplicable
Solución aceptada
So,  I solved it by creating a custom lisp, my first one :cara_con_una_leve_sonrisa:
(defun C:CS ()
(command "select" "cp")
(defun C:CSS ()
(command "select" "wp")
Thanks anyways for your replies!
No aplicable
Hi! I would also like the polygon back instead of the lasso, but I'm not advanced enough to understand how to employ that lisp? any recommendations?
0 Me gusta
neaton
If you want lasso sometimes remember a lasso selection is click and drag, whereas polygon window is click, click.
If you want to turn off the lasso option all together in Options, Selection, deselect Lasso check box.
Nancy
No aplicable
Same as PICKAUTO 1
0 Me gusta
