I need to create a set of standard template drawings that will use a specific Site Layout xref which we receive from the customer, however there is equipment that we provide that is standard. The issue I am having is the locations as well as orientations of our "standard equipment' will need to update based on each project.
I am curious if there is a way to attach text and annotations/notes that will update based on the appropriate xref layout you choose or if anyone has any recommendations on a good way to layout a template drawing where viewports will have to be changed based on the locations of our "standard equipment"?
Thank you very much, all comments are welcome.
