Creating a 3D letter without using the text
Hi! I am a beginner in autocad and I would like to create a 3d text like the picture below. If you're looking in the front view, you can only see the letter M and if you look at the side view you could only see the letter N. Could you give me a step by step instruction on how to do it exactly liked the attached picture below? I tried to use the text tool but it seems that it is much better if I would just use a box then extrude those. Is it the best way to do it?
Accepted solutions (3)
dzanta
Cool 3D text....!
I would do one of the following methods:
Method 1:
- Create the letter M and letter N using basic line command (outline form) and then use Press/Pull to make it look thick
- Select the extruded N and move/rotate it accordingly
Method 2:
- Create the letter M and the letter N via the dtext command separately.  Check under Express Tools to see if there is an explode command to take them to linework....then do method 1 via Press/Pull.
Hope this helps.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Depending on your font choice this might not be too hard to do.
I used Arial for this example. I created two pieces of Mtext (M and N)
I then used the Express Tools Text Explode (TXTEXP)
I then cleaned up the letter outlines and joined them into plines.
Next, I presspulled each one to the width of the leg of the M.
I then rotated the N and attached it to the leg of the M.
Is this what you are looking for?  I have attached my file for your examination.
John Vellek
dieters
To perform the operations described, you will need to become familiar with the following commands:
TXTEXP, EXTRUDE, UNION
3DORBIT for changing 3D views, visual styles, projection style, PLAN to return to a 2D plan view
UCS ZAxis option to establish an axis for 3D rotation, UCS World option to return the UCS
ROTATE, MOVE, COPY of course
If you plan to create your own letters, then I'd suggest creating them using ordinary geometry. To create closed polylines for extrusion from the geometry, use the BOUNDARY command.
Hope this helps,
Dieter
Dieter Schlaepfer
Principal Learning Experience Designer
Autodesk, Inc.
San Rafael, California
Thank you so much for the help, the three people here who responded so fast are all correct. Thank you for giving me a detailed step by step instruction.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
