Create Table from existing text
matthew.scottVP8DB
Message 1 of 13
matthew.scottVP8DB
I have an .dwg that was created from an exported 3D program. This results in a BOM table that is a block.  When exploded the block is just lines and MText.  My goal is to create a table that I can export into a spreadsheet.  Any ideas?
Replies (12)
Message 2 of 13
JBerns
@matthew.scottVP8DB,
Did you try any of the solutions from this forum?
https://autocad.space/autocad-text-to-table/
Let us know if this is helpful?
Optionally, post a sample drawing for the community to work with.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 3 of 13
matthew.scottVP8DB
@Anonymous Thanks for the response.
I had discovered Data Extraction but am having some difficulty.  I have a table of text 25 rows, 12 columns = 300 items.  I can extract the text into 300 rows of data, but they are not organized in any order.  I have even tried to define the selection set by picking text objects one-by-one to try to get them organized into some order, no luck.
Message 4 of 13
JBerns
I did some more Googling:
Try this lisp routine:
https://cadtips.cadalyst.com/tables/convert-plain-geometry-tables
Video tutorial:
https://www.youtube.com/watch?v=5nusUNEDkUg
Let us know of your success.
Jerry
CAD Administrator
Message 5 of 13
matthew.scottVP8DB
@JBerns LISP routine worked perfectly. Thanks for the leg work!
Message 6 of 13
arshad_iqbalEPGJT
Community Visitor
Community Visitor
"cot " lisp is working in cad 2021 & less
but not working in autocad 2024
Message 7 of 13
pendean
Community Legend
Community Legend
It works just fine here in 2024 and 2025: can you share your DWG file where this does not work?
Message 8 of 13
MSchille-1994
This link no longer works.
Attitude, not Aptitude, Determines Altitude
Message 9 of 13
caddude
It looks like CADALYST dig some reorganization of their website and that link is now broken.  I found links to the actual script here located in this post: https://forums.autodesk.com/t5/autocad-forum/make-autocad-table-from-lines-and-text/td-p/2895384
Message 10 of 13
will_young
If you print the dwg to pdf (or have a table as a raster image) you could use Excel both for converting pdf or images to tables.
Windows snipping tool also has a converter for smaller tables.
Excel vector based pdf import
Excel table from raster image
Windows snipping tool table from raster image
Message 11 of 13
caddude
Thanks @will_young!!  I didn’t consider trying to convert it first. I’ll give that a try 🙂
Message 12 of 13
dgladfelter
If you plotted the exploded table to a raster format, the Raster Design toolset (included with AutoCAD) has a Recognize Table command.
Donnie Gladfelter
Virtual Design Manager, Dewberry
The CAD Geek Blog
Facebook |Twitter |YouTube |LinkedIn
Message 13 of 13
caddude
@dgladfelter oohhh!  I’ll try that one too!  Thank you! 🙂
