Make AutoCAD table from lines and text
neilyj666
Mentor Mentor
Message 1 of 14
neilyj666
I have a Civil 3D AECC table that I want to use in Excel but these entities can't be copied and pasted. I have exploded it a few time to get simple lines and text and want to convert these into an AutoCAD table for export to Excel.
I have searched forums and have found a few lisp routines (e.g. maketable.lsp at http://cadtips.cadalyst.com/content/alspsol0308-convert-old-table-new-table-format) but they don't work - has anyone got a lisp routine that will work for this??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (13)
Message 2 of 14
Jeff_M
I have not tried it, but this has been recently posted and modified:
http://www.theswamp.org/index.php?topic=35884.0
You will need to be a member of the Swamp (free registration) to view/download.
Jeff_M, also a frequent Swamper
Message 3 of 14
neilyj666
Thanks for the link Jeff - I have just downloaded the lisp, run it and it works fineSmiley HappySmiley Happy
A bit bizarre that the functionality (i.e. export AECC table to csv) isn't built into C3D - one for the wish list...!!!
Message 4 of 14
markus.logdal
Since im a total beginner when it comes to handling .lsp files, can you guide me in how to use this .lsp?
Thanks in advance
// Markus
Message 5 of 14
neilyj666
Download the lsp routine, unzip to a suitable folder (mine is in C:\AutoLISP)
Type APPLOAD at command line
Browse to lisp routine and LOAD, then close dialog
Type COT to run and follow prompts
Message 6 of 14
hi,
that theswamp site does not allow registration, it says 'Sorry, registration is currently disabled.'
Could you pleease share their lisp with us here.
Thanks in advance
Message 7 of 14
olsonwinston
Community Visitor
Community Visitor
Attached is the most recent version of the file. Hope this helps.
Message 8 of 14
najowa
This lisp doesn't work for me neither does another one I have.
Does anyone have any others?
Message 9 of 14
neilyj666
WBLOCK the text and lines you are using to a new dwg and post it
Message 10 of 14
najowa
I was using this one and it stopped working on this table
Message 11 of 14
neilyj666
Original data above and my converted table below
Make sure all polylines are exploded to lines and that there are no duplicate line objects - there is one above the DESCRIPTION.
I then ran COT.lisp, deleted some rows then centred the text
2018-11-16 15_04_04-Autodesk Civil 3D 2019 - [D__Downloads_new block.dwg].jpg
Message 12 of 14
najowa
When I explode and delete the line and run COT.lisp it only makes an empty table for me.
Message 13 of 14
neilyj666
Can you post both the drawing with the empty table and the lsp to check - won't be able to look until Monday but someone else may be able to give some advice
Message 14 of 14
neilyj666
This is the one I use - similar to the v1.6a routine posted above - which worked earlier
