AutoCAD Forum
Create a stand-alone table from Xcel without an OLE or Data Link
8 REPLIES 8
Message 1 of 9
1108 Views, 8 Replies
I need to create a table from data in an Excel spreadsheet. However, I don't want to use a Data Link or OLE - the table on my drawing has to be a stand-alone version that can be changed and edited without depending on the original spreadsheet. Our customer has made it clear they don't want any external links.
Can that be done?
Thanks.
8 REPLIES 8
Message 2 of 9
dmfrazier
Yes.
Copy the range of cells in your XLS. Paste as table (which should be "Paste Special" option) into your DWG.
Message 3 of 9
cadffm
Sure, draw it 😉
Or use CTRL+C (you excel cells)
and PASTESPEC <AutoCAD Objects>
I don't know why you say NO OLE, i guess the important point is NO External Links??
Perhaps the are missing informations about OLE
Sebastian
Message 4 of 9
in reply to: dmfrazier
That creates a link to the external spreadsheet, which the customer doesn't want.
Message 5 of 9
in reply to: cadffm
I tried that but the data can't be edited.
Message 6 of 9
cadffm
About your both last answers: you did something wrong.
Upload a sample xls(x) and your result (*.dwg file),
Sebastian
Message 7 of 9
dmfrazier
"That creates a link to the external spreadsheet..."
Not for me, it doesn't. Apparently we're doing different things.
When pasting, select Paste Special (I do it from the Edit menu) and paste as AutoCAD entities. (When I just did this, it doesn't create an actual TABLE entity; it creates lines and text. So I'm correcting myself.)
Message 8 of 9
Using the "paste as entities" option worked.
Thanks!
Message 9 of 9
dmfrazier
Good news. (Now go ask for a raise. 😉)
State of Sustainability Webinar
AutoCAD Inside the Factory
