AutoCAD Forum
Create a gml document with autocad
3 REPLIES 3
292 Views, 3 Replies
Hello, i am trying to create a gml file with Autocad, but when i  download the .zip file (the one needed to create this gml document) and try to open the .lsp file inside this other one Autocad wont let me open it. I don't know if the problema is Autocad or the file i'm trying to download from the internet, but it's the only file uploaded i can find. I'd appreciate it if you could help me.
Thanks very much.
3 REPLIES 3
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Do you get a warning when you try to open the file?  Have you tried adding it's folder location to the Trusted path in Options?  I can try it on my computer if you can share the file or a link on where to obtain it.
John Vellek
beyoungjr
Not sure if I'm following but I'll try...
Unzip your zip file to a location of your choice.  If you intend to keep a library of LISP routines then make a folder somewhere.
Use your left mouse button to drag and drop your LISP file (XXX.lsp) into your AutoCAD drawing.  Respond with "Load Once" so you can test it before you commit to further use.
Once loaded you can type the designated name for the routine to make it execute (maybe gml is the executable name?).
I'm not sure of what you LISP file is intended to do but that's a short on getting it going for a test drive.  If it works as anticipated then respond with "Always Load" the next time you drop it into a drawing.
Hope this helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
ChicagoLooper
It sounds like you're trying to draw a map. The extension .gml is geography markup language and cannot be read by plain vanilla Cad. To verify, go to the Application button (the big red A in the upper left corner of your monitor) and select Import=>Other Formats then click the 'Files of type' dropdown to view the types of files that are supported.
If you have, or know someone with Civil 3D or Map 3D, then send them the gml file and have them perform a Save As for you. The only other alternative is to find the 'data' in a format other than gml such as, but not limited to,  dxf or dgn.
Chicagolooper
Technology Administrators
AutoCAD Beta
