crazy annotations
crazy annotations
Message 1 of 14
crazy annotations
Hi, This recently happened to my file. Not sure how or how to resolve this. I have tried selectionannodisplay, scalelistedit,-scalelilstedit, reset of scales,deleted annotation scales, turned off my add scale when annotation scale changes. It is CAD 2015. Any assistance would be appreciated.
I have also restored from a previous version and this issue is not present. but because it has been worked in I can not go back to the previous version.
Thanks, Lanee
Replies (13)
Message 2 of 14
TheCADnoob
Would it help if you selected all the text and turn off annotation as well as make it a uniform text height in the properties menu?
CADnoob
Message 3 of 14
@ TheCADnoob, I tried your suggestion and all the text became really small and disconnected from its leader. Im not sure how this happened but I appreciate the suggestion. Open to others.
Message 4 of 14
Todd_Rogers
Is this model space or a layout? If it's model, did you scale the drawing?
Todd Rogers
Civil Administration
Message 5 of 14
pendean
Community Legend
Community Legend
share the DWG file please.
Message 6 of 14
john.vellek
HI @Anonymous,
You indicate that the text is in Leaders? I suggest that you attach your file so I can examine your Style(s), your Scaling, and dimstyles. I hope to provide a quick and easy solution for you.
In Styles I suggest you remove Annotative Scaling and set the Height to 0.
You should now be able to Qselect all the text, and in properties assign it a height.
Similarly, go into your Dimstyles and turn off the Annotative feature.
Please post your results so I can assist you with this issue.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 7 of 14
The above view is in model space. The drawing is 1:1. The annotations were done in the viewport in paper space. Which was fine for several months than I work in a few days and this happened. not sure if there is a command for this?
Message 8 of 14
john.vellek
HI @Anonymous,
Try creating a new viewport, copying the annotation over to it and verifying the Viewport scale.
John Vellek
Message 9 of 14
Here is the DWG file.
Message 10 of 14
Todd_Rogers
Toggle on the buttons shown below...
Todd Rogers
Message 11 of 14
I have attached the DWG in another post. I would like to keep the annotation incase I need to modify the viewport scale. The text will adjust accordingly.
Message 12 of 14
@Anonymous, I have tried those toggles already 😞
Message 13 of 14
john.vellek
HI @Anonymous,
I went into your drawing and removed all the annotative scales except 1:1 on your blocks and on most of your text.
I then changed your modelspace to 1:1. Everything is pretty much showing up normally. You can then try to add (selectively) the annotative scales back to items if necessary.
I am not sure why your leaders don't associate with the text any longer. This might be part of the damaged that was caused.
I have attached my copy of your drawing to see if any of this helps.
John Vellek
Message 14 of 14
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
