Crash
Crash
Crash
I use AutoCAD 2014; this week it seems to just shut-down -after only a few minutes.  I've uninstalled and reinstalled the software, yet the problem continues.  Any suggestions would be much appreciated.  Screen shots are attached.
Thank you,
-Susan
user181
Did you install the service pack it shows available in the pic 2017-06-09 (2).png? What operating system are you using? I don't think 2014 is supported on windows 10
Thank you, yes, I did install the service pack, as suggested. And I have
been using Windows 10 for several months, and only had this problem for the
past 4 days .....
-S
Alfred.NESWADBA
>> I have been using Windows 10 for several months, and only had this problem for the past 4 days
Just a guess: 4 days ago Windows 10 Creators update was installed?
If you do have a system restore point available, try to get back to that state.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
THANK YOU, your suggestion worked!!! I was able to restore the system back
to the previous Windows 'BUILD'. and my AutoCAD is working perfectly!
THANK YOU!!
How do I prevent the automatic update from happening again??
-S
Alfred.NESWADBA
Glad it worked! 😉
>>>click<<<
- alfred -
Alfred NESWADBA
