- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a Dell Precision M6500, OS windows 7 Pro sp1 64 bit. Could I run Autocad Architecture 2016 on it?
Link copied
@TarunoVega hello, you can check it <<click HERE>> system requirements to run autocad 2016. thanks
welcome @forums.autodesk.com!
There are three essential informations missing
Without these info's no one an say "yes" or "no".
As @ennujozlagam already mentioned the system requirements are a good point to start, but the minimum requirements have to be understood as "minimum requirements for minimum size of projects"!
- alfred -
Hi, Alfred:
Thanks for responding! My laptop It is a Dell Precision M6500 running Win 7 Ultimate sp1 64 bit, Intel Core i7 CPU q740 @ 1.73 GHz, RAM: 8GB, with an ATI FirePro M7740, driver 8.632.1.2000. I don't know much more than that. And my projects are small to medium size, residential all of them.
Could this info help you at all to decide your advise?
Taruno
>> RAM: 8GB
1.73GHz is quite slow, 8GB is for small projects ok, medium projects could get critical, but I would say ok to start. Just make sure that within the laptop you have place to add additional memory later in case you recognize that you need it.
- alfred -
Thanks, Alfred!
I may end up buying a used Toshiba Satellite P-75 A7200 that could do it a bit better, according to my techie; but is good to know that in a pinch I could use my Dell for 2D drafting.
I can't see the "solved" button in this page but I am happy with your response.
Thnx,
Taruno
