AutoCAD Forum
COULD data link be updated automatically
7 REPLIES 7
Message 1 of 8
4967 Views, 7 Replies
I have a data link as an excel file. I have that link in many pages of my drawing set. If I change some parameters in the excel. I have to open each sheet and click download repetitively. Are there any ways to update the data link automatically? just like an xref
7 REPLIES 7
Message 2 of 8
HI
Use this command
DATALINKUPDATE (DLU)
Message 3 of 8
This command only works in 1 CAD file!! I still need to open them one by one.
I am seeking the method to update automatically each time I make change of the data link. Not open the cad file one by one and use this command.
But still thanks!!
Message 4 of 8
john.vellek
Hi @Anonymous,
Have you considered placing the update command into a lisp file such as acaddoc.lsp which would load at start?
I think this syntax might work:  (command "DATALINKUPDATE" "_U" "_K")
John Vellek
Message 5 of 8
in reply to: john.vellek
thanks!
Would you like to share some instruction or documentation about how to make the lisp file load automatically when I open the file? Thanks
Message 6 of 8
john.vellek
Hi @Anonymous,
I have attached the lsp file. Put it in your AutoCAD support path and that should work. ( I hope I got the syntax correct as i don't do much Lisp programming anymore).
I'm sure a Community member can help out if I got it screwed up.
John Vellek
Message 7 of 8
pendean
Message 8 of 8
cadffm
Like pendean said: Put it in your AutoCAD support path.
Try before: (findfile "acaddoc.lsp"), if response "nil" then all is fine and you can place the file in supportparth (standard supportpath or in your own, Options/Files/)
If resonse is a filepath you should add this file with the content of the file from pendeans attachment.
Sebastian
State of Sustainability Webinar
AutoCAD Inside the Factory
