AutoCAD Forum
Copying to clipboard
5 REPLIES 5
373 Views, 5 Replies
For some reason, I cannot copy to the clipboard now using CTRL-C? Worked fine on Friday?
5 REPLIES 5
ampster40
Does this happen with all files or just one file?
rkmcswain
How do you know for sure? Maybe the Pasting is failing?
Presuming you're trying to copy AutoCAD entities to the clipboard....
Open your %temp% folder in Explorer.
Sort by date, newest at the top.
Now do a Ctrl+C and copy some entities to the clipboard.
Switch back to explorer.
Is there a new DWG file at the top of the list?
R.K. McSwain     | CADpanacea | on twitter
in reply to: rkmcswain
Well, when I di a CTRL-C, the command prompt is still waiting for the
command. I don't get the "COPYCLIP select objects" line, just back to the
command prompt. Only happens on one file?
_____________________________________________________________________________________
Kevin J. Pinks | Schneider Electric | End User Business Group -
Industry Business | Plant Solutions | Telemetry & Remote SCADA
Solutions, Mechanical Draftsperson & Document Control
Phone: +1-613-591-1943 ext. 79387 | Fax: +1-613-591-1022 |
Email: Kevin.Pinks@schneider-electric.com | Site:
www.schneider-electric.com | Address: 415 Legget Drive, Kanata, Ontario
K2K 3R1 CANADA
*** Please consider the environment before printing this e-mail
in reply to: ampster40
Just one file
K2K 3R1 CANADA
pendean
Restart your PC yet? Sometimes that clears gremlins.
Or your setup or PC changed over the weekend: consult your IT department.
AutoCAD Inside the Factory
