Copy with base point via key commands not working
Message 1 of 16
Hi
I'm hoping someone on here can help me.
My copy with basepoint via the keyboard has suddenly stopped working.
As you know, I would normally press CTL+SHIFT+C to copy with base point, but now all of a sudden, nothing happens.
I can get it to work via the command line and ive checked the CUI and I can see copy with basepoint is correctly mapped to CTL+SHIFT+C.
Has anyone got any ideas on what might be the problem?
Thanks in advance
Mark
Replies (15)
Message 2 of 16
imadHabash
i suggest to follow some solutions mention here . >> Click <<
Imad Habash
Message 3 of 16
Hi
Thanks for your reply. Ive tried the solutions listed but its still not working.
Can I just add - We are using Autocad 2019 at the moment, ive just downloaded 2020 to see if it works on that and it doesn't.
Would you say its something to do with windows itself?? All of my colleagues machines are able to copy with basepoint via key commands.
Mark
Message 4 of 16
Alfred.NESWADBA
I hope you have NOT migrated settings, otherwise you would have imported the issue too!
If so reset your AutoCAD profile for 2020 and see if it works then.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 5 of 16
alex101000
Do you have any additions to AutoCAD? The drawing does not contain a proxy?
When copying a line or rectangle from a new drawing, does the combination of buttons work?
Message 7 of 16
Kent1Cooper
Faulty keyboard?
Kent Cooper, AIA
Message 8 of 16
Thank you! It seemed to be conflicting with Radeon Pro graphics https://www.cadforum.cz/cadforum_en/the-ctrl-shift-letter-hotkeys-do-not-work-e-g-ctrl-shift-c-tip12...
Ive disabled the screen record and its working now.
Message 9 of 16
ACADY7VVU
Check your Radeon video card setting, mine had the same shortcut for video, which over rides CAD.
Message 10 of 16
RobDraw
Did you read the post above yours? The one that's marked as a solution? The one that says pretty much the same thing.
Or were you just finding posts about copy/paste issues and just copy/pasting your "solution" regardless of any mention of a Radeon video card? Not everyone uses those.
Rob
Message 11 of 16
I am using AutoCAD 2022. I want to select two lines without using shift.
I select line 1. Then without shift, I select other line, the first line selected becomes unselected.
Any solutions?
Message 12 of 16
Kent1Cooper
@Anonymous wrote:
.... I select line 1. Then without shift, I select other line, the first line selected becomes unselected.
Any solutions?
Set the >PICKADD System Variable< to 1 or 2.
Kent Cooper, AIA
Message 13 of 16
solved the problem for me. thanks
Message 14 of 16
refraley3
Observer
Observer
Thanks.
Message 15 of 16
adam.rahman
Community Visitor
Community Visitor
THANK YOU! I've been annoyed with this for a while and it was a Radeon hotkey overriding my CAD commands.
Message 16 of 16
mostafa_algamal
Community Visitor
Community Visitor
hot key
