AutoCAD Forum
Copy/paste to clipboard failed
5 REPLIES 5
7471 Views, 5 Replies
The original drawing was made with Linear so partly in 3D
At work I work with autocad LT 2015 but autocad 2016 has the same problem.
To locate the cullprit, all layers transferred to layer 0. (see attachment)
Autocad LT2015 on Windows 10 professional 64 bit , 8 GB ram.
Autocad 2016 on Windows professional 64 bit 32GB ram.
Draftsight, Bricscad also when opening this file, copy/paste error.
ps; don't look that lines are not linked,  the arc's have been removed
Z=0
Can anyone verify the problem or at least has a clue why copy /paste is not working on various cad applications?
5 REPLIES 5
Vinayv4v
Alfred.NESWADBA
You'll need to have the application to copy & paste geometry from one drawing to another.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
imadHabash
>> Can anyone verify the problem or at least has a clue why copy /paste is not working....<<
i suggest to do the follow :
  • Audit and Purge (Regapps) commands.
  • SAVE AS your drawing as .dxf file type.
  • close your AutoCAD.
  • open the new dxf file from autocad.
see now if your issue is resolved.
Imad Habash
in reply to: imadHabash
That's the first things that I've done:
First audit, then purge.
Dxfout and then dxfin even between autocad and bricscad and draftsight.
if you open the dwg, a message says proxy  etc but I see no proxy  at all, just circles, lines, text, and poly lines.
Arx applications not being used should be purged.
I even got super purge and hard purge to a level that the drawing does not disappears  , still no copy/paste to clipboard.
Strange enough, there is something copying but no  paste , see clipavu and paint pasting the clipboard.
So what is saved? A Bitmap instead of lines etc.
And , autocad and other cad applications can not paste from the clipboard.
Microsoft paint could paste the clipboard contect.
I did copy the problem dwg so all on layer 0 and no arx applications  to a USB stick and here on autocad LT  copy/paste works.
I guess that I had to restart the computer instead of closing autocad 2016 and restarting autocad.
Still strange that closing an restarting the application did not solve the problem.
So problem now known and solved.
AutoCAD Inside the Factory
