AutoCAD Forum
Copy / Paste Problem
6 REPLIES 6
michaelcooley
777 Views, 6 Replies
I created a new layout tab from the Page Setup Manager.  I cannot paste a Drawing Title from an existing layout tab to the new layout tab in the same drawing.  I can paste the drawing title to all previous existing layout tabs in the same drawing.  There's something wrong with the new layout tab.  All layers are on and unlocked.  I can paste text to the new layout tab, but not certain blocks and symbols.
There are no error messages, it just doesn't work...
Thank you,
Michael
6 REPLIES 6
nestly2
in reply to: michaelcooley
Check to see that the Layer(s)  (including those that may exist inside the block) are not VP Frozen.
michaelcooley
in reply to: nestly2
Thanks nestly2,
There are no frozen VP's.
Please see attached photos.
I copied the drawing title and text from existing layout tab, and you will see how it pasted in the new layout tab.
I can paste the drawing title and text in all other layout tabs except the new layout tab.
Michael
kcobabe
Are they annotative?
Make sure the light bulb above annotation visibility is on.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
CAD_SNOOK
Not really sure what you mean by Drawing Title, I assume you mean title block?
Anyway, why don't you try right-clicking an existing layout tab and just doing a copy of a tab that works?  Then just update the new layout tab, delete viewports, text, etc.  Or you could just right-click on a tab and create a New Layout?
michaelcooley
in reply to: kcobabe
Thanks kcobabe!
That worked!
It was the annotation visibility.
Michael
kcobabe
Yeah I field that question everyday here at my office.  Very easy to forget about that sucker 😉
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Forma Design Contest
AutoCAD Beta
