Copy/Paste error from AutoCAD to Inventor Sketch
Message 1 of 17
Hi!
I have an error, when copy from autocad 2017 to sketch in inventor 2017.
I have seen this page: http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-93153D08-1766-41D1-9951-D2C9A14F3605 but it does not fix that
And
I have an error, when open or copy and paste object by Ctrl+C, Ctrl+V on the Autocad 2017.
I think these two errors are related to each other but i can't fix it .
Can you help me fix it!
Thanks!
@Anonymous
john.vellek has edited your subject line for clarity: ERROR COPY AND PASTE.
Replies (16)
Message 2 of 17
jayhar
To be check CAD file, use wblockEXPORTTOAUTOCAD if you tired these two commands, COPY/PAST to new cad file and save.
Then you try to past sketch in inventor 2017.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 17
alex101000
Try this or this link
Message 4 of 17
Thank you!
I tried it but cant' fix
Message 5 of 17
hi @Anonymous
 why you need to copy the sketch from autocad to inventor? Is there any special reason.
or what is your final need please tell me.
Message 6 of 17
jayhar
1. You may want to add the missing language support to your Windows - e.g. asian languages, cyrillic (Control Panel > Languages, Regional settings), or you can just ignore the message (especially if the codepage is "undefined"). Just check the drawings texts and symbol names (block names, layer names...) for possible garbled characters, missing accents, etc.
2. re-install of Autocad to see if this fixes your problem
3. try  DXFOUT  at the command line and DXFIN
Message 7 of 17
There are some drawings which I want to copy (i don't want to redraw it).
Message 8 of 17
I do not know what language is missing.
I did Reset Settings To Default - Autocad but it's still error.
Dxfout, Dxfin all can't fix it
Message 9 of 17
Thank you!
I tried it but cant' fix.
Message 10 of 17
jayhar
Can you please upload AutoCAD 2013 format?????. Delete all Layout...
Message 11 of 17
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Perhaps this is a stupid question but have you tried opening the dwg with Inventor instead of using a copy/paste?  Have you tried freezing all the text prior to the copy/paste?
The error looks like it is having issues with regional settings (OS perhaps does not match the localization of the applications).
I am happy to look at a dwg and this work flow if you can provide a sample and some more details about your computer.
John Vellek
Message 12 of 17
Itried Open -> Import DWG
Can you help me!
Please!
Message 13 of 17
Message 14 of 17
jayhar
Message 15 of 17
Hi, jayhar
Thanks for the solutions!
I tried it but it's error.
Message 16 of 17
john.vellek
Hi @Anonymous,
Please share one of the AutoCAD files so I can test this on my side to determine what might be causing this issue.
John Vellek
Message 17 of 17
Thank everyone!
I found a solution for copy/paste from AutoCAD to Inventor Sketch.
Control Panel\Clock and Region\Region\Adminitrative (tab)\Change system locale...
and UNCHECK  Beta: Use Unicode UTF-8 for worldwide language support
