Im just learning autocad 2016 for my job which consists of me updating oil pipe drawing revisions with circuit numbers to each pipe. Each layer is a circuit number. Is there a way to copy layers from Revision A to Revision B or a way to just replace rev a drawing with rev b while keeping the layers and adjusting what ever change was updated which is either adding or deleting a pipeline. They have me starting from scratch on each rev which i think is a waste of time. Thanks everyone for sharing any knowledge. I really appreciate it.
Yes, it wastes time really.
1st of all, is there a drawing standard in your office? And do you use vault?
If your answers are "no" to above, you may save your last revision to a new file for new revision. Then make changes on the file.
2nd, are you going to copy layers from a drawing file to another?
You may have to ask your manager for how to updating drawing. This is not a drafting technique issue. This is more likely a company drafting standard issue.
A simple answer to the copy/paste layers question.
1. Type layerstate in command line, "Enter", then click "new" in the dialog.
2. Click "Export..." to export that new layer state.
3. On other drawing file, Type layerstate, "Enter", then click "Import..." in the dialog to import the layer state file (*.las) that you created.
HTH
