Copy from edit Xref in-place to another drawing
I am using autocad, and im editing an xref in place.
I want to ask if there is a way to copy the objects  from the xref  im editing to another drawing.
Please help me.
natasha.l
Hello @Anonymous,
I briefly remembered the process, but tested it out to refresh my memory. Smiley Happy
It will not work with all commands like for example, you can not use Copy during xref editing.
Copy Xref objects into a new drawing:
  1. Select the xref & use the "Open Xref" command it will open the linked file
     2. Select objects to copy & right click "Clipboard > Copy at Base Point "
     3. Go to the new drawing & right click "Paste" into the new drawing file
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
RobDraw
You can easily get the objects from the XREF into the current drawing by using NCOPY. If you need them in a different drawing entirely, you can cut them from the current drawing and paste to the desired file.
Rob
imadHabash
Hi and Welcome to AutoCAD Forum,
While you're in reference editing , there is NO way for that.
  • ** COPYCLIP command not allowed during reference editing **
  • ** COPYBASE command not allowed during reference editing **
  • ** WBLOCK command not allowed during reference editing **
Imad Habash
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue.
