Has anyone else noticed that Copy and Move seem "jagged" in 2021 compared to 2020? It's almost like the F9 snap is on, but not that drastic. I have tried it on 2 different computers and get the same result both times. One install is a plain vanilla install and the other had migration, but the results are the same. Has anyone else seen this?
Win 10 Pro, Core i5, 32gb ram, AMD FirePro W5000, all drivers up to date, Graphics config set to 2D Advanced mode (although changing that made no difference). It's small, but it's annoying.
Solved by STECH0315. Go to Solution.
@sdvannelli - I'm not seeing that here. Looks and feels the same as it always has.
Here is the top of 2020:
and here is the top of 2021:
No idea why the "Feature mode" is different. It's the same card on the same computer. I also attached the actual tuner logs from both. Also not sure why 2020 & 2021 show 2DRETAINMODE differently because they are both set to off, and changing to on made no difference. As I said, this is very slight, but I can pick it up both in the object and the rubber band attaching the object to the base point. Any suggestions would be appreciated.
HI,
would you please attache here a screencast to show us your issue , and post it in a new post ?
Imad Habash
@STECH0315 schrieb:
I am having the same problem.
Also in a new created DWG [acad.dwt or acadiso.dwt] with, never saved in older formats than dwg2018,
only new created objects [nothing imported, no xref to older files]?
For usual such a clean created file works well, is it the same on your side?
Sebastian
Thats unusual.
Please create such a file and draw a line, saveas(dwg2018) and upload this file here.
Sebastian
For anyone having this issue, please do what @imadHabash suggested and create a Screencast so that we can SEE what it looks like to you. This will also let us SEE other things perhaps.
Turn ON the visibility of ALL of your status bar icons before making the screencast please.
Yes you did!!! Thank you!
What's odd is that this variable has been around I believe since 2016, and you never had to change it before. ACAD 2020 works perfect with it set to 20, but changing it to zero definitely cleaned up 2021.
Interesting. I'm running a fairly low end PC for CAD (i7-8550U @ 1.80GHz, 16GB Ram, Radeon Pro WX 3100) and I don't see a difference either way with AutoCAD 2021.
Thanks for the update.
As an added 2021 issue that seems related, rectangular array also has an issue. Changing INTELLIGENTUPDATE to zero made it much better. To best see it, change INTELLIGENTUPDATE back to 20, make a simple vertical line and do a rectangular array. Notice that if you pull the arrow to increase the number of items, the added items disappear until you stop pulling the arrow. If you go back to 2020, the items updated live as you pulled the arrow. Changing INTELLIGENTUPDATE to zero helped this also (not quite as smooth as 2020, but much better). And as I mentioned in my last post, 2020 worked perfect with it set to 20 - there was no need to change it. Hopefully this helps Autodesk figure it out.
