Is there a way to display coordinates such that the X, Y, Z displacements are displayed? As far as I can tell, all the modes display either the actual coordinates or the "polar displacement vector" however, I would like to display the ΔX, ΔY and ΔZ from the base point. Possible?
>> Is there a way to display coordinates such that the X, Y, Z <<
regardless of how do you want it to display . i suggest to use ID command that it may help.
Imad Habash
I think you're being misunderstood by earlier Replies. If I understand correctly, you're looking for an option in the running display in the Coordinates slot in the tray at the bottom of the screen, as you Move or Copy or Rotate something, or are giving it the next point of a Line or Polyline, etc. Is that correct? [If so, I don't know of a way to get that.]
You got to togle COORDS with CTRL+I or by clicking directly on them or by typing 'COORDS followed by the change of the value (between 1 and 2, 0 meaning that u choose to turn them off).
Yes you are right. It was late at the nigth and I was busy with another thread yesterday.
But I'm convinced MODEMACRO and DIESEL should offer a solution for your "deltas" need
There is a possibility that DIESEL is enough. With Autolisp, it should be easier, "delta-ing" with LASTPOINT variable.
I'll be back. Anyone who knows is welcome to anser but it should possible to do something.
Oups : i'm thinking : it is not possible to read the position of the cursor when you are in action unless you use GRREAD in lisp. But GRREAD needs complication to use snaping.
So I beleive one the best solution is to macro a UCS change before moving and then a step back in term of UCS.
What kind of manoeuver, what action do you plan to do ?
I may also have misunderstood and I'm not sure why you need to see the DeltaZ since mouse dragging will only affect the X and Y coordinates in the current UCS but
First of all, thanks to the forum for all the responses. Usually when I want to move/copy an object I don't really need the actually world coordinates of the new position. Sometimes, I just want to "see" what the "relative displacement" is. The polar coordinate display in the "tray" is actually exactly what I'd like but instead of showing the polar "displacement , angle" I'd simply like the ΔX, ΔY and ΔZ in Cartesian coordinates displayed. It seems there should be one more display option, say "COORDS = 4" (or whatever) that displays the ΔX, ΔY and ΔZ relative from the base point. I guess that's not possible. at any rate, appreciate the reply's and suggested workarounds.
also, if you have an osnap set while dragging, the coordinate display in the tray will show the coordinates of the point it is "osnapping" to, so the delta Z would also be displayed.
You are right.
It could be useful. I agree and I must say that I pretty am a user of this device.
But I must say I'm satisfied with its polar version.
^c^c_ucs;\;_move;\;0,0;\_ucs;_p
This is a macro I made for you but it is only for the move command. In case of failure, your _ucs may be a _ucs that you don't want to have but it is easy to retrieve a Previous UCS, isn't it ?
The problem is that my little solution is only made for one command. You need to build as many macro as you want to adapt any command.
(edit)
Even better :
^c^c_ucs;\;_select;\_move;_p;;0,0;\_ucs;_p
