Hi
I need to insert on my autocad 2015 coordinates for example N 41 26 44.1 E 19 42 07.3 Could tell anyone what can I do ?
Is this what you are after?
http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-104722CD-FA08-4A8B-A2E6-DA4670D0F3FD
FIELD command line is your need for such case.all what you need is to prepare block as attached CAD file. then double click on E text with in the block then right click then go for insert field till dialog appear for you(see attached image).
- follow attached image to know all needed info.
- the text field will read the coordinates from the head of arrow.
- when you move or copy the attached block type regen to see all new coords.
and here with CAD file i prepare it as a sample. i hope it's help.
Good Luck..
Imad Habash
...and another guess.
TJ,
One way would be to convert those Latitudes and Longitudes to UTM Coordinates:
http://home.hiwaay.net/~taylorc/toolbox/geography/geoutm.html
http://www.earthpoint.us/Convert.aspx
http://www.latlong.net/lat-long-utm.html
N 41 26 44.1 E 19 42 07.3 would be X=391575.84 and Y=4589035.93. The good news is that you can use GeoLocation to use Bing Live Maps.
Dave
Dave Stoll
Las Vegas, Nevada
