Does anyone out there in Autocad land have a quick easy way to convert a multi-sheet drawing to single drawing files? I have a drawing with multiple layouts on it with a separate drawing on each layout that I need to put into a format in single drawings that I can add to my project in Autocad Electrical 2015. Anyone know the best way to do this?
God bless you! that just saved my life! I haven't used model space/paper space in a while, so I forgot about that one. Awesome! Thank you so much.
FYI exportlayout will export each layout to separate file, but it will move your layout information into modelspace.
Attached is a lisp routine you an load which will automatically separate all layouts in drawing to individual cad files (layouts remain in paperspace)
each file will will have the name dwg_layoutname.dwg for the format. It's been very handy for me.
you can try with Layout Manager which is a free tool availabele to download from Autodesk Exchange store , gives more contorl on export layout, like save version, location and file naming etc.
watch the below video
https://www.youtube.com/watch?v=FIitx6gtUIM
Hi I'm looking for the exact opposite of this ...
I know right-click from template method - but I have 10 files I would like to combine
Does anyone know of a LSP for importing multiple individual sheets into one multiple-layout file?
Hi, very late reply: This one
"Or do you have 10-modelspace files with a single layout in each and you want to add the modelspace content into one DWG file then automagically create a layout for each and every one?"
The model space content is the same in each file, I want to consolidate each layout in the multiple files down to one file with multiple layouts - keeping the names of each layout within each file
I have 1000 plots drawn as a single layout. like a whole layout of a area. now i have to draw as individual layout for 1000 plans as plot 1,2,3... etc. now do i need to draw 1000 individuals or is there any shortcuts
@riswanthespy написал (-а):I have 1000 plots drawn as a single layout. like a whole layout of a area. now i have to draw as individual layout for 1000 plans as plot 1,2,3... etc. now do i need to draw 1000 individuals or is there any shortcuts
No problem, use this - Revers
This is what I am looking for... I'm grateful. It helps me save a ton of time.
