converting dwg to PCX during plot missed some lines in the same layeyr.
Message 1 of 22
To feed another software I need to convert dwg to pcx. During plot after conversion some lines of a drawing missed which conversion to pdf kepp all parts. So it seems it is just cause of converting to pcx. And in preview all part are there in place.
Is there any solution out there ?
Replies (21)
Message 2 of 22
First capture is pcx output and second is dwg.
Message 3 of 22
imadHabash
can we know your plotter name and how you create it ? also we need your CAD dwg file please ?
Imad Habash
Message 4 of 22
From the menu select Tools -> Wizards -> Add Plotter…
Select My Computer and Next
Select Raster File Formats and Zsoft PC Paintbrush PCX… continue with Next.
Continue with Next.
Select Plot To File, continue with Next
Define a name for the plotter AutroMaster.pc3 and continue with Next.Select “Finish”
When the drawing is ready to be converted select from the menu. Files -> Plot
To change the size of the plotted drawing select Properties
Verify that 256 (8 bits color) are defined under Vector Graphics.
Resolutions earlier defined are shown under Custom Paper Sizes. Select on of these or use Add to define a new resolution. I set it W:1680 H:1050
Message 5 of 22
imadHabash
check my below attachments ( 60-SG21-00-J01q-0002-Layout1.pcx ) file and see if it's ok ?
waiting your feedback !!
Imad Habash
Message 6 of 22
It seems perfect. the capture was just to show what is the issue. I normally should make a window over yellow rectangle (attached) and paper size 1680x1050. May I know how did you fix it? There are several pages I should go through.
Message 7 of 22
imadHabash
I've just create the plotter and prepare my settings for plotting . see below image
Imad Habash
Message 8 of 22
higher rsolution, less lines miss. Please do the plot to pcx over the whole yellow rectangle in paper size like W:1680 H:1050.
I attached the plotter file.
What would be the problem then?
Message 9 of 22
Here is mine and the pcx attached.
Message 10 of 22
imadHabash
see attached !!
Imad Habash
Message 11 of 22
it is the same as mine, some part of green drawings (J-Equipment layer) still missed.
Message 12 of 22
imadHabash
see this one below please .
Imad Habash
Message 13 of 22
file is damaged and not opened.
Message 14 of 22
imadHabash
Ok!! i get more better result when i plot your dwg to a pdf file and it was perfect . then i use online convertor ( pdf to pcx )  >> Click <<, try it and see if it's good enough . 🙂
Imad Habash
Message 15 of 22
the software that I should use pcx for has problem with online conversion, I tried it before 🙂
Message 16 of 22
imadHabash
in general ... AutoCAD is not the proper software for create images !! you have to expect pixilation and more !!
Imad Habash
Message 17 of 22
pendean
Community Legend
Community Legend
Read this, you have to do more than just accept the stock offerings https://thesourcecad.com/how-to-get-high-resolution-images-from-autocad/
Message 18 of 22
I accept to loose the resolution quality but at my case it is selective and nothing happened on umbers and just on one specific layer (J-Equipment) some lines are removed. I admit that resolution can be degraded but being removed is odd.
Message 19 of 22
I exploded all those green blocks and match the lines with a rectangle I drew. and now all lines are shown in PCX. Seems the block setting has problem which I can not find. and just exploding the block didn't solve the issue until I match the properties with the one I drew. Any suggestion to fix the block? then all drawings using the same blocks will be fixed.
Message 20 of 22
imadHabash
draw a new one and convert it to a block with same name to redefine it OR use Express Tools BLOCKREPLACE . >> Click <<
Imad Habash
